Strange bulb issue on Delco radio (04' GMC Yukon)
Sergeant Dreizehn
USA
Hello,
I've been repairing a bunch of dead bulbs on my mother's 04' GMC Yukon, in the radio and the instrument cluster. Most of the repair went fine, but there is one 3mm radio bulb causing strange issues. When removed from the circuit board, the bulb works fine. However, once soldered in, the bulb is really dim, even if I apply the current directly to its leads. I've tried two different bulbs and re-soldering (admittedly I'm still learning soldering), but the result is the same.
I think the traces on the board are ok, but I don't know for sure.
Does anyone have any suggestions on what it could be or what I could try? Or if not, perhaps another place I could ask? Any assistance would be much appreciated.
Thank you.
P.S. The final attached image, of the radio face, is from Jennies Garage on YouTube, which has a great video on replacing the radio bulbs. I forgot to take a picture of the face of mine. Sorry for the messy soldering. radio (1).jpgradio (2).jpgradio (3).jpgradio (5).jpgradio (5)other.jpg
Hello,
Thanks for the suggestion. At the moment someone on Maker Pro is trying to help me out, but if that doesn't pan out I might try a Yukon forum. And I know what you mean, Yukons are everywhere! I frequently have to check the license plate to be sure it's my mother's vehicle in a parking lot. ^_^;
Hello,
Good luck.
Ok, but it sure seems strange that every other speaker I've ever seen has it wired to the positive, And they switched later too. It kind of goes...
838
Have you contacted crutchfield.com support. They sell modules that allow you to retain the steering wheel-controlled factory features for some...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
They managed to turn Covid into a wedge issue.
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
Sergeant Dreizehn
Sergeant Dreizehn
USA
Jimi77
    May 16, 2024
    May 16, 2024
