2 Alpine R-SB10V on S-A60M?
  • 2
nealuss
Hello all, first time poster here. Title pretty much sums it up. Basically I currently have one Alpine R-SB10V (Halo series linkable prefab) on a S-A60M. The amp is rated for 600w @2ohm but the dyno sheet states it tested at 850w rms. I just bought a second R-SB10V I will be getting an R2-A150M (1500w rms suggested by alpine) when I can afford it, but that may be a couple of months. Should I go ahead and set up the second sub with the amp I have or just leave the 1 until I can get the right amp? Will it be better, worse, or about the same?
Being that the sub is wired to 2 Ohms, you will have to wire the other in series for a 4 Ohms load. That will then be 165 to ~220 watts RMS per sub. That should sound better than 1 sub at 600 to 850 watts RMS.
Re-edit- will this be in a trunk?
325
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
660
nealuss
nealuss
Clayton, NC
    May 10, 2024
3toneEYZ
    May 10, 2024
