2-dvc4 ohm 12’s
tbcopeland1
I have a separate chamber ported box. I’m looking to achieve a final impedance of 1 ohm at the amp. What’s the best way of doing this? I have both subs wired parallel with both being tied to a terminal cup being as I can’t run wire from one sub to the other because of the box limitations.
So in simpler terms how can I get 1 ohm with 4 speaker wire leads?
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)?
How many sets of +/- wires and what are the individual impedances?
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
It also lowers the amps efficiency and raises the current draw.
528
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
tbcopeland1
tbcopeland1
North Carolina
    May 20, 2024
    May 20, 2024
