Sub sensitivity
kanihoncho
What is a good sensitivity that I should I be looking for in a sub when my 4ch speakers have a sensitivity of 93 dB (at 2.83 V). Should I be looking for similar specs or is it a completely different equation? I do see different sensitivities at different voltages and do not know how to compare them . . .
Sensitivity is usually measured 1watt 1 meter. I'd go by that.
Higher the better on subs too. Less power to get louder. Every 3 DB gain is like doubling your amplifier power.
Getting a good voltage reading does not mean good power transfer. You could read 13.8v out of a 24 AWG wire. Recheck your amplifier's ground and...
142
519
552
647
kanihoncho
kanihoncho
South Carolina
Jimi77
metalheadjoe
    Jun 5, 2024
    Jun 5, 2024
