Sub sensitivity
kanihoncho
What is a good sensitivity that I should I be looking for in a sub when my 4ch speakers have a sensitivity of 93 dB (at 2.83 V). Should I be looking for similar specs or is it a completely different equation? I do see different sensitivities at different voltages and do not know how to compare them . . .
Sensitivity is usually measured 1watt 1 meter. I'd go by that.
Higher the better on subs too. Less power to get louder. Every 3 DB gain is like doubling your amplifier power.
235
382
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
787
521
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
378
kanihoncho
kanihoncho
South Carolina
Jimi77
    May 16, 2024
    May 16, 2024
