2005 Ford Focus ZX4/ Front subwoofer upgrade/odyssey/nightmare? 6/2/2024
  • 6
Welcome back man!! Deff a tight spot there... But Hey?? Let it roll .Ha Ha!! Love it.
You Deff. have some creative crafting skills man, and some really focused and layed out plans for your build and driver locations. Always Interesting to see whats Next!!
Thx brohamster. I've really wanted to get a large fullrange on axis in the car. If I still had my 550I I could definetly done an 8",but my focus is small. We'll try a 5" first, then maybe upgrade to a 6.5" If you have an IG you can see a bunch of other stuff I havent posted here. @kevinmccradic
Here are a few more pictures of the mounts for the "salad bowl" enclosures. I put down a layer of tape, and drew a template so I knew where my outline was. Then I used hot glue and wooden dowels to get the initial form that I could cover in some reinforced fiberglass.
This is why I like working with bamboo. The next couple of photos show me trying to glue a dowel rod to the others but it is straight. It doesn't match up with the contours of the panel. In the second photo you can see by some "cooperative" bending the wooden dowel takes the shape of the door panel. You can feel the fibers being crushed when you bend it. Its a satisfying sensation. You can't bend it into a circle but it does move quite a bit.
Once all that nonsese is complete we end up with something like this..
Then we add a little reinforced filler and sand...
So that's where I'm at. The next step is to mount the salad bowls to the bases and use more dowels and reinforced fiberglass to get a cool shape. Hope to have more for you sunday.
So I'll hit ya with some pics straight off...
So the midbass trim panel has been covered and they have been wired up not screwed down yet. I spent a good amount of time working on the fullrange at the top of the door and the glove box sub today.
I added a same little section to face of the subwoofer so it closes up the gap where it meets the kickpanels. There was a 3" open space and it was driving me crazy.
After I added a couple layers of reinforced filler and sanded this is where were at. ..
Here is a closer shot. You can see the two holes on the right of the enclosure. These are two of the three mounting locations. I used some m6 rivnuts and sank them into the skeleton of the dash.
So that brings us to our next post. The 5" fullrange in he door.
So this has been a pain in the butt as I will show you. The fabrication is the normal stuff but getting the two to line up and match is proving difficult. Still I do have some progress photos that I can share with you.
Like the previous post. This is the goal. They are meant to be cross firing with a slight upwards tilt. This pic shows the frame with the popsicle sticks already attached.
Here is a shot of the drivers side temp glued. As you can see the alignment is off. The left still needs some bodywork so they will match closer. I did this three times. lol And let me tell you; crawling into the back to take the photo everytime must have been hilarious to watch.
It might be saturday before I get to post on the build so stay tuned.
feeling my jodeci on my headphones...
So, as you can see the glove box subwoofer is complete. It has taken, like.. so long to get done. I am more than happy with the results. Here are a few shots of the "sausage being made." Up front. I hate wrapping panels. **** gives me profound anxiety. lol
I added a layer of deadener for "just cuz" and drilled the holes for the hardware. Looking back I definitely want to put some hurricane nuts in there with some epoxy. I'd rather have a machine screw rather than a coarse thread. Especially with mdf. It's just so prissy. I'm online looking for some machine hardware as we speak. ...
Hahaha. you can see the wiring for the front sub I haven't tucked in yet. I'm awesome.
And an update on the fullrange on top of the doors. . . I've added a couple layers of kitty hair to the panels. The shape is coming out pretty nice. They are not symmetrical yet as I need to add some height to the passenger side enclosure. IMG_0671.jpgIMG_0672.jpgIMG_0674.jpgIMG_0680.jpgIMG_0681.jpgIMG_0682.jpg
My expertly placed index finger shows the area I need to fiberglass up to. I'm not really sure how long I want that "tab" to be. In my mind it looks more like a swept back wing of a fighter jet. I may take a lot of material off there. I'm not sure. We may get called off for rain tomorrow so we'll see..It may be a few days before the next update.
View attachment 58361View attachment 58360View attachment 58362
Dammned!! Looks great to me man!! I bet it serves well up front. i plan on two Dayton Audio 80 RMS tens under the front seats of my truck later on. Ive been itching to get back at it. Moving has taken my time along with working. Hopefully in later just before winter Ill be busy on it??Hmm. Hopefully.. Last SPL build out than pull and do an SQ/SQL type system. Looking at all that Badd Azzed installing, I didnt even notice the wiring.. LOL 😁 👀👀:poop:
Thanks brohamster. I've been trying all these crazy ideas and they keep working.
Ill add more photos as we go along but you can see I am tightening them up. Getting them to match. Another 10-ish hours they will be ready.
View attachment 58444View attachment 58445View attachment 58446View attachment 58447View attachment 58449View attachment 58448
Looks Badd azz man. You have some patience for sure. Something I need to have more of. Im deff. going to play around with some F.Glass to experience it some. Ive never done any all these years
So, it has been a while since I have made an update. I had the front sub up and running but the coil delaminated. ...on 70 frickin' watts. All right, cool; so I use the backup I had. Nope, This one runs for like 10 minutes and I start hearing noise. I order another. Install it. Cool. This one isnt fu@%^. Nope. Halfway through a track and the damn thing flatlines......Magic smoke and all. So I go looking around and they aren't even for sale anywhere. That's telling me too much. Definitely a rockville sort of situation. Poor coil gluing caused delamination. .?
I ended up doing some research to find a sub that would fit as the geometry of the enclosure is...difficult. I ended up finding 4 drivers that had the right inner and outer diameter but the depth was the real challenge. I bought two different GRS subwoofers from Partsexpress. The one I ended up installing was a high excursion model GRS 10SW-4HE. Here is a couple photos of the new sub installed.
Ill try to get some better photos in a couple of days. In the mean, I have two Soundstream mono blocks coming. They are the compact versions. I also got my other 2 Lisa's (4 channel) from US Acoustics. Thats 6 amps total. I also bought some brackets so I could stack the amplifiers. They were spendy but definitely worth it. Now we need to get one more dsp and a large AGM for the trunk. I want to do a lot more of research before I go to a lithium setup. To be honest I could probably power my entire system on a Titan 8 on an isolator and I may end up doing that.
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
782
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
878
just call me KeV
just call me KeV
chicago suburbs
just call me KeV
