FEATURED Hyundai Cilantro.. I mean Elantra!
ThxOne
Premium Member
The Boss
Ok, another swap/build for me. I removed the rest of the stereo from the Escape which is now chilling in the Cilantro... I am waiting for the wire harness and dash kit. Should be a simple head unit install. I am positive I accidentally left the Kenwood mic in the Escape. No biggie, I will order another one. The sub's fit nicely in the trunk. LOTS of room.
Alternator stock is 90amp. 200amp aftermarket is available. Battery is a 124R. AGM's are readily available. Stock door speakers are 6 3/4" with a tweeter in the upper door aimed at the dome light behind my head. Should be good for imaging. I need to order 0awg power and ground again. I have all other wires and needed cables. I will run the doors off the 4 channel active through the Kenwood head unit. Doors will be deadened. A lot. If I do this right it should sound better than the first G6.
The car has an aftermarket alarm tied into the factory keyless entry. I have already fixed the headlights and installed "6000K - 6500K" H7 LED low beams. It has begun!!
Build Photo
  1. Okay
Took the car for a spin to town so I could test the head unit. The lights match the dash perfectly and it really woke these stock mids and tweeters up. Very loud on head unit power. Step one, done. I did decide that since the tweeters are mostly "on axis" I will run soft domes.
Step 2 will be getting the aftermarket door speakers done and the sound deadening.
Step 3 will be running the RCA's and remote to the subs as well as the 0awg power and ground and big 3.
Step 4 will be new amplifiers.
Step 5 DSP? Maybe? If I do, I don't want another 360.3. I am thinking the A.C. DM-608 or similar.
1/0awg KnuKonceptz amp installation kit ordered and on the way. When I removed the subs and amps from the Escape I left everything connected. Distribution blocks, all the 4awg cables, everything. All I have to do is hook up RCA cables, the remote and connect the power and ground cables to the distribution/fuse blocks and I am up and running.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
74
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
454
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
641
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
12
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
ThxOne
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
