0 to 80hz sweep for gain setting using dmm
  • 2
ExplsvCookie257
Maryland
I had an idea that using a sweep of frequencies of that which your sub plays, is better to use for getting the correct voltage because all frequencies are there to affect the voltage instead of just 60hz. Would this be worth a try, or should I just use a lower hz 0db tone like 20?
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
684
I hold firm on the deposit in all situations 😎
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
ExplsvCookie257
ExplsvCookie257
Maryland
ExplsvCookie257
    May 12, 2024
Brendon Jenness
    May 11, 2024
