Wiring in amp to bose system...
  • 4
Steve19Ohio
Ok here is what I have installed in my 01 Audi TT Coupe
Audi Concert Model: 8N0 035 186 A
Bose Sound System Model: 3511
Both came with the car from the factory. I wan to add a 12” sub in the trunk but I would like to keep the stuff I have in there already. The only issue is that the speaker wires coming from the head unit use a common ground wire. So how to I wire in my amp? Do I just connect both ground wires to this one? Any help would be great. Thanks…
Oh the AMP I want to install in addition to what I have is a Kenwood KAC-5204. Thanks again….
Hear is the pinout for the headunit
Yes sorry not to clarify that. The amp has speaker lvl inputs I would like to use. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The amp I want to install is a 2 channel amp. So it has Left and Right both with separate grounds. However the head unit has only one ground for all speakers. Sorry for not being clear. I don't know much about car audio.
hey i just installed a 15 inch in my a4 and i used a Line out converter or a speaker level input (my amp had it) i got the signal from the rear speaker tapped into it. then i ran the remote wire to the factory amp that was in the back with the 6 disk. then ran the power to the battery like normal. everything works as of now. im not sure if its the best way to do it but it works for what i want. you might want to do some more research but i hope this helped thanks.
Thanks for the info. but I'm sorry to say I have no rear speakers. I have woofers that come out of the amp in the back. The thing is I can't splice into them because I read that Bose has a Mic in my car to automatically adjust the bass so I can't blow my speakers. So if I were to tap into that my amp would be controlled by the Bose amp... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
385
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
937
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
6
Steve19Ohio
Steve19Ohio
Las Vegas
Steve19Ohio
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
