1/0 and 4 ga wire crimpers ?
I use hydraulic crimpers. Or solder all the other crimpers aren't as good as you think. Except the long handle very expensive cable crimpers
ya i have seen the long ones with handle but would like to find something i could put on my vise so i can crimp some wires.
something like what you get when buying a universal spark plug wire kit ( the good kits ) it has a 2 plates that crimp the ends.
is there anything like that ?
Percussion crimps aren't good in car audio applications because they do not create a sealed connection. The long term results are that corrosion will build up inside the crimp and eventually lead to high resistance (which = voltage drops) and, possibly, noise.
Hydraulic crimpers fuse the copper wire with the copper lug and make a connection that is impenetrable. They're more expensive but the extra cost is invaluable if you want long lasting connections, solid connections.
thanks guys, i just picked up the TEMCo Hammer Lug Crimper Tool , got it from ebay.
ya if i was going to do this all the time or was rich i would get a very nice crimper.
thanks.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
390
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
873
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
993
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
997
big scott
blazin low, and loud
big scott
edgewood, md
big scott
