1/0 and 4 ga wire crimpers ?
I use hydraulic crimpers. Or solder all the other crimpers aren't as good as you think. Except the long handle very expensive cable crimpers
ya i have seen the long ones with handle but would like to find something i could put on my vise so i can crimp some wires.
something like what you get when buying a universal spark plug wire kit ( the good kits ) it has a 2 plates that crimp the ends.
is there anything like that ?
Percussion crimps aren't good in car audio applications because they do not create a sealed connection. The long term results are that corrosion will build up inside the crimp and eventually lead to high resistance (which = voltage drops) and, possibly, noise.
Hydraulic crimpers fuse the copper wire with the copper lug and make a connection that is impenetrable. They're more expensive but the extra cost is invaluable if you want long lasting connections, solid connections.
thanks guys, i just picked up the TEMCo Hammer Lug Crimper Tool , got it from ebay.
ya if i was going to do this all the time or was rich i would get a very nice crimper.
thanks.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
391
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
876
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
993
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
999
big scott
blazin low, and loud
big scott
edgewood, md
big scott
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
