1/2" MDF Box with 3/4" Baffle?
  • 4
prodgod
Bored
I'm working on building a box which is very tight on space, so I was wondering if I could make a box made out of 1/2" MDF but use 3/4" MDF for the baffle. It is going to be around .5-.6 ft^3 for a single 10" sub running around 400 watts. It will also have another piece of 1/2" MDF mounted to the baffle to flush mount the sub.
It has a decent amount of small pieces to it because I had to design it to go around some body panels, so there are no real big pieces besides the baffle.
Would it be fine to use 3/4" MDF for the baffle and 1/2" MDF for the rest of the box?
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
409
prodgod
Bored
prodgod
C-Town, WI
jshak07
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
