1 sealed box or 2 vented?
i have a decent amout of trunk space....but a very small trunk opening.
its a coupe and i would have to take bith front seats out to a dual ported box
go ahead and use two vented boxes if you cant fit one box for both. it wont make a difference if its in two seperate boxes or not
i can't see how you could fit two vented boxes and not one vented box....
maybe the opening for the trunk isnt big enough to fit it a box that big in there, but if he splits it up he can put one box in at a time
yeah...the tunk openings to small....but thats what i thought..but just wanted my sure
my friends have no idea what thier talkin bout..lol
but 2 smaller boxes will fit easy...just that wide a box wont fit in the opening
me = confused
can't fit sealed enclosure (the smaller)
but can fit 2 vented (bigger) ones????????????????
That's like saying I can't eat a 10 Oz steak in one meal, but I can eat 30 pounds of ham
If you do 2 vented boxes its a fail safe so if one sub fails the other doesn't suddenly get 2x the cubes also.
Twice the amount of space(AKA Resistance) AND the resistance of the other cone which is now acting like a passive radiator. I always try to chamber off my ported subs.
However, if you do use two vented, make all the cuts in one day, and get it all together in one day. Any slight warping has the chance of being disastrous.
me = confused
A 30"x16"x20" box is a LOT harder to fit into a trunk than a 15" x 8" x 10".
the dual ported box will fit in the trunk but not through the trunk opening...but if i made 2 single ported or a dual sealed they will fit throught the opening
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
mccoy
mccoy
pikeville, ky
GAM3OVR
    May 16, 2024
    May 16, 2024
