100watts 2 much to push components?
  • 5
Originally posted by swtguy Will it be ok to push 100 watts to each of my infinity reference 6.5 components? They are rated at 90 watts rms and 270 watts peak(i'm assuming this is to each speaker?). Thanks.
I think give an take 10~20 watts to a 6.5" shouldn't be TOO bad... I heard that infinity drivers were sensitive to overpowering, so get yourself a second and third opinion... and you could always reduce the gain a tad...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I personally think there is no need to give them 100 watts they would sound fine at 75watts and you won't go deaf as quick or worry about blowing them.
Well I got a good deal on an amp that puts out 100 watts per channel bridged x 2 or 37.5 x 4. I actually think i'm gonna use it at 37.5 watts per channel for them and bridge it and use 100 for my sub. Will I notice a huge difference going from a 150 watt amp on the sub to the 100. It is too loud as it is....
Originally posted by swtguy They are rated at 90 watts rms and 270 watts peak(i'm assuming this is to each speaker?). Thanks.
Actually the 90w RMS rating is for both the tweeter and the woofer together.
The 37.5w will push the components well. The Reference Series works
well with lower amounts of power.
You probably won't notice a big difference between 100w and 150w
on your subwoofer. And if it's too loud already you will be fine with
100w compared to 150w.
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
948
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
swtguy
swtguy
tx
ShaunMac
    May 18, 2024
    May 16, 2024
