12 Inch JL Sub-300 Watts
  • 3
steelersx49
This is my first car, and my first sysytem ive ever put in. I have a 12" JL Sub 300 Watts and am not sure what box and amp to go with? I got the amp for free from a friend, its brand new. I'm trying to stay as cheap as possible, but i do understand that to cheap just wont cut it. Any suggestions??
You said you got the "amp" for free, you ment sub, correct?
Can you build a box? Or will you need to buy one?
As for an amp I'd suggest you look for a two channel one that you can bridge for your sub. Then when you upgrade you can use it for your front channels. The amp should cost less than $100 new. You will also need an amp kit. I would get a 4 gauge kit, they are cheap and give a little bit of room to upgrade. You should be able to find one you like for about $25.
Thats a good looking sub. Ive book marked that site. I may try one out for an Xmas present to myself??
50
6K
Yeah I’m up ****’s creek. OP has gotta be more specific about his equipment and what he wants, IMO. 10’s take different boxes, so it’s hard to...
9
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
This. It's hard to beat for the money. They can take a pounding. Make sure that your amp is one ohm stable. If it isn't the buy the dual 4 ohm sub...
steelersx49
steelersx49
Pottstown PA
Why So Cereal?
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
