So is the SSD and the BL.
Then i don't see what the problem is with picking the Q. SSD's are out of stock until neos are in and the BL is meant to be a higher power handling sub whereas the Q is more SQ oriented
I was looking at the SSD's earlier then I noticed the "Up to 30 business day build time."
It is just a precaution. Check out their section on SSA. Nick talked about the 30 day build time. The new SSDs look awesome and can handle more power too. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And cost less //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. I might reconsider, I've gotta do more research.
The SSDs are in and the BL has the same power handling spec as the Q and yes, the Q is more SQ oriented but it doesn't mean the OP is going hate the SQ of the BL or the SSD.
Welll, Qs and BLs are popping up a little more in power handling as well with some slight changes to things internally. We have been tweaking things for all of the drivers and making gains in thermal capacity. Just havent made them all known on the site.
SSD now has a solid pole and ability to have heli-cool as well. This bumps up thermal capacity on them even in standard form. 30 day is to try and cover our butts a little incase of delays with production on the new drivers using US steel. We have had so many snags with things time wise that we simply would rather over estimate and come in on time or under with customers knowing what it could be, than to have to make a 100 phone calls explaining why we are later than posted for the series.
As mentioned above... I am not a fan of the Q with the extra spider for SQ applications. Sealed with the high Qts and standard suspension works great for SQ. The extra spider is for those that are a little more brutal on things but want the extra linearity of the Q vs the BL.
Thanks,
Scott
Thanks,
Scott
of the new SSD vs. Q, which would have the most potential to get lower? in 7 cubes tuned to 28, pushing roughly 1200w.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
517
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
6K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
xshlomox
xshlomox
Long Grove, IL
Fi Car Audio
    Jun 4, 2024
    Jun 3, 2024
