12" sub for my vette
VerTigo456
Hey guys,
Second guessing myself and was hoping for some advice. I have a 2001 convertible corvette. Currently I have a Massive Audio NX5 that is powering the front component and rear coaxials. I bought an Eclipse 12" Sub back in the day, I believe a 97121 DVC 4ohm? Anyways, I am going to have the box mounted in the trunk middle storage compartment. Obviously with the vette the box is only so large. I wanted to know if I should stick with this sub or if the new subs today are much much better? I am just wanting a nice tight bass line. I listen mainly to alternative and rock. Thanks for helping a newb out!
Steven
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
134
284
463
574
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
905
VerTigo456
VerTigo456
Fort Worth, TX
naughtyca
audiobaun
    May 19, 2024
    May 19, 2024
