2$ DIY clipping detector
Thanks so both wires go in line with the pos? I just want to br sure im understanding this correctly.
What i did was just adding a pos and negative run from my speaker output terminal straight to the piezo which is paralleled to the subs. The amp is seperated from the cabin so i can play both and see my clipping point with a load. If your amp is by your sub, you'll have a hard time hearing the clipping point because the bass is too loud.
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
821
hispls
hispls
Central Maine
wew lad
    Jun 1, 2024
    May 31, 2024
