2 ohm and 4 ohm wiring?? noob help!!
  • 3
dlg3413
so im bout to buy to sundown sa 10's from a friend. he bought them brand new. they r barely even broke in yet. only reason he is gettin rid of them is cuz they dont fit behind the backseat of his truck. the deal is just too good to pass up. $150 for both subs wen they r bout $200 each new. only problem is one is a dual 4 ohm an the other is a dual 2 ohm. wat r some of my wiring options?? im plannin on gettin the hifonics gladiator series 1400w amp from sonic with 0 awg power an ground wire. any opinions options feedback is greatly appreciated. this will be my first system so im gettin excited. thanks in advance
Dual 4 ohm speaker
Parallel; 2 Ohm
Seires : 8 Ohm
Dual 2 Ohm Speaker
Parallel; 1 Ohm
Seiries; 4 Ohm
Parallel both speakers together DVC 4 @2 + DVC2 @1 = 0.5 Ohm Make sure your amp can handle this.
Etheir way
electrically it can work, but power will not be evenly distributed to the subs. if one sub gets more power than the other, the result will not be worth the effort. you certainly wouldn't want them in the same box. just run one sub. if you want to run two, sell one and buy a matching pair. your friend is right to get something that matches.
one well done sub is plenty if you like music.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
5
514
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
326
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
dlg3413
dlg3413
Louisiana
dlg3413
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
