2 Rockford Fosgate T2D212's Tune Frequency!?
  • 2
MxRacer476
Hey guys I am having Ryan (RAM) build me an enclosure for my TrailBlazerSS for my T2's he suggested a 33Hz tune. The Subs will be Inverted on the top of the enclosure with the ports against the Lift-Gate. Each sub will have a Rockford T1500 to it. My question is I listen to all kinds of music. Rap, Rock, Country, and stuff in-between, excluding Death Metal, an the other end of the spectrum. I know I don't need to discuss my complete build but I will be using P2D48-S in the doors for midbass. Just wanna make sure I get a good # as it's gonna be 1" material used and wanna get it right the first time.....
Rockford's Site suggests 38Hz for this sub, so I am just wondering what is a good number to use for my broad selection of music
Thanks in advance for the insight!!
Ryan
Ok Ryan I'll go with the 33 like we had talked about....Yes mine are the new T2's (Black)
EA-2031 Compliant
Size 12"
Nominal Impedance Dual 2-Ohm
Power Handling 1200 Watts RMS
2400 Watts Max
Voice Coil Diameter 4"
Magnet Weight 292 oz. (8.28 kg.)
Speaker Connector Compression Terminal
Fs (Hz) 38.7
Re (Ohms) 3.4
Le (mH) 1.64
Qms 5.15
Qes 0.54
Qts 0.49
Vas (Liters) 13.6
Sd (cm2) 430
SPL (dB @ 1w/1m) 85 dB
Xmax (mm) 22.32
Woofer Displacement 0.151 cu. ft.
(4.28 Liters)
Cutout Diameter 10.81 in.
(274 mm)
Mounting Depth 8.875 in.
(225 mm)
Shipping Weight 57.9 Lbs.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
MxRacer476
MxRacer476
Georgetown, IL
MxRacer476
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
