Rockford Fosgate P3SD2-8 - Wiring - Factory JBL
  • 2
noveske
CarAudio.com Newbie
Anyone familiar with the wiring schematics of the JBL amplified systems?
Not sure if I wired this correctly. Was aiming for 2Ω assuming the factory amplifier outputs a 2Ω load.
Comparing with the wiring wizard on the RF site, I didn't see one that matched.
Grabbed the 2Ω sub. Maybe I should have grabbed the 4Ω and just paired the positive and negative and just ran 2 to each? Like this?
Any guidance? Thanks.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
noveske
CarAudio.com Newbie
noveske
Central PA
noveske
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
