Rockford Fosgate punch EQ work good
  • 2
TDC
CarAudio.com Newbie
Canada
Hi im running an Kicker L7 Qclass 12” sub with Fosgate p1000x1bd . I have done the Clean set up . My gain landed at just over half way mark. Amp doesn’t seem to kick super hard unless i turn up the Punch EQ on the top of the amp. The amp’s gain is set to the HU so there’s the power i have available and its not enough unless like i said it needs abouthalf way on punch dial any thoughts? Thanks.
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm
If you’re at 2ohm you’re not feeding it enough power. At 1ohm that amp probably delivers 1400-+ at 2ohm check your spec sheet to see what your p1000 delivers.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
TDC
CarAudio.com Newbie
TDC
Canada
2023 LTZ
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
