2005 Chevy Trailblazer LT Bose Stereo problem (Crackling, Distorted noises)
  • 1
Pubsy95
Hello everyone,
I currently own a 2005 Chevy Trailblazer LT. Around three months ago, I started to hear a somewhat loud buzzing sound that could be drowned out if I turned up the radio. Finally, it got really bad and I couldn't listen to music or the radio. I would move the center console around and it would make a huge static sound almost like fireworks but after moving it around, it would fix the problem. It was kind of like moving a bad guitar cable and it finally works in a certain position. My car has a console in the back seat which turns off all back speakers and allows whoever is in the back to listen to music through headphones. I noticed I could use that and be able to listen to music without the static noise. I did that for about a month and all the sudden the device started smoking and I pulled it out. Now I cant get any sound and sometimes it sounds like fireworks going off through my speakers. I can put the radio all the way up and hear a small amount a music, almost like if I had the radio barely on but only sometimes it outputs noise. I removed the center console and noticed a cable was burned through, which I replaced. I don't think I have a short since the fuse would have been blown. I don't know if the amplifier has a short in it or something is not properly grounded. Please can anyone help? I will attach videos of the noise!
Edit: The noise is extremely loud even when the volume is at 1%. It's so loud that everyone turns and stares at my car.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
777
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
6
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
Pubsy95
Pubsy95
bloomingdale, nj
Pubsy95
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
