2005 Infiniti G35 Coupe by JML Audio of St. Louis
JML Audio
We recently finished phase 4 of this full integration for current G 35 forum member "VIV" hence the subwoofer grill. This next phase has many unique things to it that completly blend into the factory look. For example the subwoofer level controller is now located at the previous toggle knob location for the factory nav control panel. The factory nav monitor which is no longer used for navigation is now a rear vision monitoring system so he can see behind him all the time while driving. After some circuit board modification to the camera it will always send video to the top monitor but still trigger on the lower one when you back up so you do not have to have the upper monitor on while backing up. Our new custom ipod mounting system "4th generation" with thrumserts is also in place. Every piece you see is HAND Machined in house by our expert team with over 40 years experience in custom mobile electronics between the 5 of us. "This perticular vehicle is a lease by the way, which means that we did not cut any of the factory panels so the vehicle can be put back to stock at the end of the lease" Hope you like the finished product. Any questions or comment you can always forward directly to us jmlaudio@hotmail.com. If any of you are in St. Louis, MO or would like to make the trip out let us know so we may set up some times for you to seen and hear this perticular system. Thanks for your time and feedback
The Vehicle itself in the installation and fabrication facility
Multimedia Source Unit
Dedicated Subwoofer controller
Stock monitor shows rear view full time
Double Throw rear view trigger
Rear Vision Camera
Navigation System
Custom Tweeter Pods "better staging without losing almost any footroom"
Custom JML Audio Ipod Mounting System "Generation 4"
Custom Fiberglass Subwoofer enclosure that houses a Single 12" driver
Subwoofer enclosure and 1st level of amp rack "We really sweat the details"
This is the same G that has been seen previously built. When Jim "the owner" decided to upgrade amplifiers and subwoofers he wanted to go for a show look that was not stealth but the complete opposite. When simply asked by us, "may we play" he confidentially said, "go play". The result is seen below. Good bye trunk, hello show.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
788
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
JML Audio
JML Audio
St. Louis, MO
four15s
