2005 Toyota Sienna
  • 3
Ray Forsythe
CarAudio.com Newbie
I have an 05 Sienna with the factor 10 speaker JBL system with Navigation & back-up. Can i just replace the factory speakers with new component speakers.
Will i need to use the aftermarket crossovers or should i just install coaxial speakers.
Thank you,
Ray
Thank you,
Ray
more than likely, it'll sound worse than the factory speakers because the factory head unit and factory amp has built in EQ curve and filters that are tuned specifically for the stock speakers to make up for their low quality parts. The stock speakers also have a proper baffle, factory seal that redirects sound perfectly into the vehicle cabin and is designed to work infinite baffle and is full range meaning it'll actually play sub-bass. The aftermarket speakers will be subjected to that which means it can sound really nasty and peaky or lacking in a lot of areas in the frequency response. You wont have any bass out of the door speakers either because literally every aftermarket speaker is designed to play midbass and up, not subsonic bass and with the stock amp, you'll be severely underpowering the speakers as well. Usually speakers need at upward of 75 to 150 watts to get proper potential out of them.
TLDR f you arent planning on replacing the head unit or doing some factory integration DSP, along with adding an amplifier and sound deadening your doors, DONT BOTHER swapping out your speakers.
Yikes.  That's some sobering advice.  Would you give the same advice for someone with a standard, lower end 6 speaker system (non-JBL)?
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
786
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
6
https://www.sonicelectronix.com/ci95-2005-buick-lacrosse-wiring-harness-to-install-a-new-car-stereo.html?sort_order=price_asc lots of options...
6
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
579
Ray Forsythe
CarAudio.com Newbie
Ray Forsythe
whatwillhappenif
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
