2007 Hummer H3 stock radio no sound/door chimes
  • 2
buckwheat42
Hello all! I recently purchased a 2007 H3 with the stock Delco radio with 6 disc changer. It worked up until
two weeks ago when we had a bad rain and flooded the passenger side floor board, and I believe that whole side
of the dash got wet. Now the radio turns on and functions properly aside from having no sound and door chimes
are silent as well. I checked all the fuses for damage and continuity and found no issues. I did do a parasitic draw
test and the radio seems to be pulling 1.75 amps with the car off, doors closed, and key out. This problem is also
intermittent. When I hook up the multimeter, I get that reading of 1.75 amps, but after 5-10 seconds, it reduces to 17 milliamps, which I believe is acceptable. Does anyone know what I should test next and how? I have a multimeter, a tone generator/wire tracer and lots of time.
Water or moisture on any Electronics is never a good practice nor a great out come of operating correctly . If you want to keep that same unit, Id recommend looking at a Salvage yard for plug and play. They usually pull them out when wrecked vehicles come in and store in a dry place
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
The harnesses showing up for your vehicle show one or two adapter plugs. If your car has a separate CD player, then I assume that is what the 3rd...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
897
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
152
buckwheat42
buckwheat42
Florida
audiobaun
    May 18, 2024
    May 18, 2024
