2011 malibu problem
  • 2
streetdreamz
I just installed an aftermarket double din. I've done almost a hundred installs and never seen this. I used the cheaper harness because I didn't care too much about losing the chimes and all that. I ran the ignition wire(red) from the harness to the radio fuse and also tried the windshield wiper fuse. Both times the radio turned on with the car off. But the bigger problem is that I have no sound and I have an ABS light on, brake light and a few others on. I've never seen this before. Is there something I don't know about? I also installed new door speakers. When I put the factory radio back in I have no problem. thanks
Use a dmm to find a suitable switched power wire in the car. Pink or orange at the ignition harness. Lights coming on is because you need the data harness. The radio in those and many other new cars is way more than just a radio. Many other components run data through the radio and the proper interface keeps everything functional. Don't cheap out and buy a walmart data harness as I've heard many shops having problems with various lights coming on and other issues from the cheap harnesses. There is a reason parts are made to do installs properly on these newer vehicles.
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
701
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
6K
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
streetdreamz
streetdreamz
cleveland
AVX Mike
Decebal
    Jun 10, 2024
