2011 Silverado Backup Camera w/ stock HU
  • 2
Hybrid13
I have a 2011 Silverado with the Bose package and the Nav HU. I would like to be able to turn on the stock backup camera while in drive. It would be useful for when I'm towing my boat. I have found the wire that sends power to the camera and have wired it to an accessory wire to come on with the truck. I having trouble figuring out how to make the HU swap the the camera mode/input. I tested all the wires going into the back of the HU for any change in voltage from park to reverse but found none. I'm kinda leaning toward it being some kind of signal rather than a measurable voltage. Any ideas? All help is greatly appreciated.
Its a signal coming from the prndl switch sensor.
If you follow the wire going to the transmission youll find a wire that goes to the camera and one to the ecu.
To bypass it youll need to get the wire that goes to the ecu and camera and add on a wire that connects both with a switch to turn it on and off.
Or have someone change your computer for you.
Changing the computer will block access to the radio since both cant be on.
So really a bypass will be needed.
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
596
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
6K
Hybrid13
Hybrid13
Coden, Al
los33
