absorption is increased with thickness or density or both. most cars are limited to 2 inch available depth on the back wall anyway. it is difficult to compress batt insulation and have it hold its shape in a bag. the ceiling tiles are ideal and nearly identical to acoustical wall panels we use on walls for sound absorption anyway. You could use two or three layers to get more thickness without the pillow Effect. the main concern is interference with the window movement and linkage. loose bags have been problematic. The compressed ceiling tiles are ideal.Some responses in red above.
Thanks!
no. it is important for the cabin to be absorptive and a good acoustical environment.If you don't have speakers in your doors, is sound deadening enough to reduce acoustic losses?
i also did this in the wife's carMakes sense. I don't currently run drivers in my doors (Kicks vented to exterior), but my wife's car will. I'm working on a build in her corolla so I'll give it a shot there.
note that i applied a liberal mount of sound deadening to the plastic rings and added foam seals. my end product does not look like a simple plastic adapter.I have a question about those plastic speaker mounting adapters for your mids? I have 2011 Honda Accord and I was going to make some mdf rings. Are you actually saying that those Scosche rings do a good job? What do you mean the mdf rings resonate. I always thought mdf was better for a strong, solid mount.
Getting ready
painters drop cloth, 1 mil thickness. $3 for a bag.Quick question for you-
Where do you get your pvc plastic sheeting from for encasing the fiberglass batt? Are you looking for specific properties of it?
I'm gathering the supplies needed this weekend.
Thanks
yep, deaden the rings and they'll be great. if i thought MDF would be better, i would have built mounts with it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifSo, if I "deaden" my rings, will I be o.k.? Components are Focal 165v30. I plan to mount in a similar fashion to what you have done. Keep the build logs and updates coming. You won't believe how much I've learned from following your threads.
my DVA-9861 will control the H701, as will several other Alpine HU's, so that is one option. Get her a W505 or something....to sell me that H701/C701 ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I actually have an H701, but need a RUX. If you come across one, please let me know. Of course I could always buy a complete combo and then sell my H701 as well.
I currently run the H800/C800 in my car and the H701 will go in the wife's car. The alpine's are very nice.
Thanks. Yes, i don't trust tape measures unless tolerances are high. i have a 36" but would like one at least 50".Awesome attention to every little detail. I noticed you were using machinist rulers this is all I use as well. My longest rule goes up to 60". I don't trust tape measures unless you measure from the 1 inch graduation but never the tip. All my woodworking tools have wixey digital scales for high repeatable accuracy.
