2014 Dodge Ram Crew Cab - Adding Heated Seats - Circuit Question
  • 1
MxRacer476
Hey guys,
I have installed Katkinz Leather Seat Covers in my new truck I picked up, and I have also installed 5 Dorman Universal Heated Seat Kits (628-040). Which are 10A fused to a switched 12v ckt with a relay. They want you to use a fuse tap to gain power. However since I have 5 I would like to know if I can run a 12AWG ling to power this fuse/distribution block. Then just use there switched B+ line to tie into this block, or what the best way is to go about it?
I have attached links to the Dorman Kit, and the Distribution/Fuse Block I want to use.
Block;
http://www.amazon.com/dp/B00QMTAZ1W/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=WQ5MRQAKFPE4&coliid=I11FLV9GUM7QF6&psc=1
Dorman 628-040 pdf
http://www.dormanproducts.com/digitalassets/document/628-040_IS.PDF
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
987
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
683
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
990
MxRacer476
MxRacer476
Georgetown, IL
MxRacer476
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
