2014 silverado crew - subwoofer audiomobile 2212
  • 1
I have a 2014 Silverado Crew with Bose speakers. I have a JL 10w7 but it takes up the entire back. I went to the local audio place and they recommended a prebuilt box with 2 x 12inch audiomobile elite 2212. He told me that since I knew what the 10w7 ported bass was that this was similar for small enclosure.
I never heard of this manufacturer and i was wondering what you all think. If you recommend anything else that would be great too.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
733
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
LovesHunting
LovesHunting
Edmonton, AB, Canada
LovesHunting
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
