If I wire a DVC sub at 4 ohms, output on amp is 2 ohms?
I have a IDQD4v4 and it is wired like so:
Does this mean the amp is putting out it's 2 ohm load and the sub if only receiving half that or the amp is putting out its 4 ohm load and the is getting all of that or...?
When you wire up your 4 ohm DVC sub, you can either have 2 ohms resistance in parallel, or 8 ohms resistance in series if it's one sub. So it is not wired to 4 ohms. It's not possible. If you have it wired the way the picture shows, it's wired to 2 ohms.
I have a Rockford Fosgate R500x1d.
Says it's 500w at 2 ohms, 300w at 4.
Does this mean the sub is "receiving" 500 watts?
My guess is that this amp is too small for this sub. To have headroom, I should get something that is 1000w RMS at 2 ohms, yeah?
Yes. Slightly and sure, doesn't hurt to have a little headroom
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
104
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
565
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
907
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
882
supoaneko
supoaneko
Springfield, MA
supoaneko
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
