2015 Titan Crew Cab w/ factory Rockford system. Help
  • 2
StephenS
So I'm not really new to aftermarket audio, I've just fallen really far behind. I'm wanting to add in some subs and want to keep the factory radio and was looking at best location for wiring in i.e. directly behind head unit best I'm guessing but, as I got looking I was seeing people mentioning the factory amp and having determine from there where to actually wire in to the diagram. Needless I'm confused like no other. At ththe moment I'm just adding in some extra bass and eventually working through re installing my components and 2nd amp for those. In my past I always chucked my factory radio and installed an aftermarket head unit and bam already had rca Jack's for lows and mid/highs. Now I've got a much newer vehicle and am lost. Part of the problem is me not wanting to go jacking up my wiring and have a sh** install/out come.
Any help with this would be more then appreciated! Thanks
Looks like I'd still have to run rca. Does this bypass anything i.e. factory amp.. wasnt getting much detailed info on researching this product.
That will help you replace your factory radio with a aftermarket one. It looks like it can't just do a amp replacement.
Sent from my SM-N950U using Tapatalk
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
StephenS
StephenS
Nashvile, TN
evilmonstertruk
