2018 Subaru WRX
I had pretty good results in my 2015 WRX going IB. I have an IDMAX12 I'm not using but I think I'll get another one and end up going IB. It's not that permanent of an install actually, in the last WRX I had, I was able to get everything back to stock pretty easy before I traded it in.
You'd better post pics of that if you do.  The proper ones I've seen are very permanent sealing off the trunk.
Looks like a nice job coming along.  I say IB those subs indeed, looks like they are Dayton subwoofers right?
Nice work. Those U3 speakers have amazing range. What made you want to add on tweeters? I ran my U3s from 315Hz to 20kHz and was able to get a very flat RTA response even at 16 and 20 kHz.
What sound deading material are you using? It look more like a pad than the thin butyl mat.
Any over heathing issues with your amps tucked in the wheel well?  I have mine under the seat and had a thermal shutdown a couple days ago. I need to get some fans or somthing on the amps.
Opted to show my buckeyes some love. Used some padding and also a unique piece of laminate I hade laying around. Needless to say, I’m happy it’s...
6
515
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
9
run your subwoofer amp on RCAs from your head unit. Tap the loc in the rear speakers or the wiring harness in the back of your head unit to the...
Beerdrnkr
Beerdrnkr
San Diego
sdcerreta
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
