3" Port Cuts
  • 2
well seeing how I am from Oklahoma, I would use some southern engineering in this case...I would cut a 3 inch hole and see how it goes from there, if it's too small either sand, file, or cut the hole slightly bigger until the pvc fits in pretty secure.
Jearod
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
833
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
983
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Miller
Miller
Chicago,IL
Jearod
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
