4 channel amp with 2 4 ohm subwoofers
  • 2
Brandon Bender
CarAudio.com Newbie
19
I am new to this forum so I hope I'm posting this thread in the right place. I have a 4 channel amp that can be switched to 2 channels bridgable with 2 4 ohm SVC subs. My question is what is the best way to wire them. I originally wired one subs positive and negative to one bridged channel and the other sub to the second channels bridge. Is this the best way to wire them? My equipment is amp-autotek mma2000.4 with two kicker comp s 12s and as stated before, they are both single voice coils. My amp is rated 1000 watts bridged. Any suggestions would be a big help.
Hey mate!
Thank you for posting your inquiry.  It should be ok to run your amplifier bridged to accept 4 ohm for each bridged terminals as I had a look at your amp specs so its all good to go mate!
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
254
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
599
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Brandon Bender
CarAudio.com Newbie
Brandon Bender
DRBOOM
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
