4 Channel Amp
elballz12
I just you some Alpine door speakers online and i need some help on buying an amp. They are rated at 110 on the components and 100 on the coaxials. They are the Alpine SPR-60C and Alpine SPR-60. Trying to hurry up and get an amp so I can install it all at one time. Just need suggestions
Another suggestion.. Precision Power P900.4. 4x140watts at 4ohms. Very compact box size, cheap. Though, if you can afford Alpine PDX or JL Audio, those should be a little better IMHO.
I wouldn't read too much into Alpine's "110watt" RMS rating for its speakers. Mechanically speaking, I doubt they can take so much power without bottoming out unless you set crossovers well over 100Hz.
Yes it is at a store in my town. I can under power that isn't a problem with me just don't want to over power them and i probably would with the kappa. The alpine is the most expensive so i want to make sure if I'm gonna drop the money on it that its worth it
6
117
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
552
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
716
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
elballz12
elballz12
Decatur, AL
elballz12
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
