4-channel wiring
  • 2
dannyz122001
need some help really quickly...
Kicker DS69.3 (140 rms, 4 ohm) in deck, DS65.2 (120 rms, 4 ohm) comp set in front, run off of RF 400.4 (50x4 @4, 100x4 @2, 200x2 @4 bridged)
I'm not sure how to wire them all, as far as mid/x-over/tweet plus 6x9's. A simple diagram or explanation would be awesome! Thanks guys.
Just run the comps off the front ch's and the 6x9's off the rear.
Wire the mids and tweets to the x over on each side, them run the wire to the amps. And then just hook up the rears to the rear channels.
Am I missing something? Seems like hooking them up is self explanitory.
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
dannyz122001
dannyz122001
Baton Rouge,LA
Sleeklsc
