5 channel amp install
  • 2
Battman98
CarAudio.com Newbie
5
Hello, I am planning on installing a 5 channel amp into my 97 gmc sierra. I have 4 pioneer door speakers, and a 12" sub, I plan on using rca cables to work all speakers and sub from the amp to an aftermarket stereo. I am also replacing all speaker wire so I can run it to the amp. Would I still need to use the factory harness for anything besides power wires? I plan on doing the install this week or this Wish me luck!
I'm onto my 3rd 5 ch amp install, so I can tell you right now those plugs would be useless. You would need to solder the new speaker wire onto the speakers or using some sort of connecter onto the terminsals of the speakers. With the exception of the HU....don't cut that harness!! There's installation kits out there on the market that have plug and play with new wires to hook up to the factory wires.
The issue is that i had my vehicle broken into so the wires were cut already. I tried installing in a new stereo but no bueno. I was gonna run speaker wire to amp then the amp comes with a rca wire kit for all 4 speakers and sub from amp to stereo.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
85
6
333
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
713
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
822
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Battman98
CarAudio.com Newbie
Battman98
Battman98
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
