New Car & Stereo - Unsure Which Adapter Is Needed
  • 2
Christina Tipton
CarAudio.com Newbie
Hi,
I’m hoping someone can help me find the right adaptor for my car stereo.
It’s my first car, a Volkswagen Beetle 2001, and the stereo is a Sony one (see photos). The previous stereo was taken out of the car so I’m not sure if I have all the right wires to get this one set up.
I’ve attached photos of the stereo and the wires that I’ve currently got in my car.
I did originally take this to Halford’s but they said they didn’t sell the correct adaptor and that I’d have to find this on Sony’s website.
Does anyone know the correct adaptor, and the best/cheapest way of getting this?
Thanks in advance for any help! :)
You should have got a plug with some wires sticking out with the Sony CD player to plug into the back of that Sony unit.   If you do not have this there's a problem.  Did you get the head unit brand new?
Best one stop shopping for the install kits you'll want is Crutchfield.com   Simply plug in your year make and model (you also might need to know if you have the upgraded factory sound system to get the right adapters).   You may need a dash kit, wiring harness, and antenna adapter.  Crutchfield has been around a long time and they're known for good customer service.  They're generally pretty good for phone support as well.  You will need these parts (Metra or Schoshe brands most likely) in addition to the Sony plug that should have came with your CD player.
Best Buy should also have (or be able to order) all these parts but it might be hit or miss getting the right ones depending how competent the installer at your local store is.  The guy up here has been installing for 20 years or so but I suspect most stores aren't so lucky.
From there, you just match up the color wires on one side to the color wires on the other.  If a color is on one and not on another side tape it up and ignore.   Crimp connect or solder and tape.
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
7K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
858
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
Christina Tipton
CarAudio.com Newbie
Christina Tipton
hispls
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
