5 channel vs 4 channel and a mono block
  • 3
Adel
CarAudio.com Newbie
10
Germany
Hi everyone,
I currently have pioneer gm-d8701 mono block wired to TS-D12D4 , connected @2 ohms , sub is 600 rms and the amp output is 500 rms output at 2 ohm
I have a pioneer Dmh-z5350bt headunit running the stock speakers in a mercedes w211, the headunit output 22 watts continues and 50 max.
I'm thinking about adding an amp for the stock speakers, for better sound quality and detailed sound.
Should I get the 5 channel pioneer GM-D9705 , with 75 watts × 4 @ ohms, and 600 rms @ 2 ohms
As a 1 amp solution
Or
Just buy another 4 channel
Pioneer GM-D8704 , 100 rms x 4 @ 4 ohms
Thank you
Hi everyone,
As a 1 amp solution
Or
Thank you
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5 ch is usually pretty pricey compared to getting two amps. Get a 4 ch, or two ch for your front stage and leave the sub duty amp in there serving the substage
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
  • Locked
Will trade for pair of 6.5 subs or a single 10 shallow
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
311
Adel
CarAudio.com Newbie
Adel
Germany
audiobaun
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
