8 channel Bluetooth amp with dsp or Minidsp +?
  • 4
Brax1942
CarAudio.com Newbie
15
Arkansas
So I am building an iPad mini based system that will play straight from my iPad to my amps. I have been told that I need at least an 8 channel amp (for a pair of 3 way components and 2 subs) and that the amp needs to have Bluetooth and preferably dsp.
With that said, can you guys suggest an 8 channel Bluetooth amp with dsp? I want to keep the cost down as much as possible while still accomplishing my goals. If I could do this for under a grand that would be nice. If not, then I will do what I have to do.
Would I be better off with a 6 channel and two sub amps using a Minidsp with 8 outputs?
It depends how much power you need for subs. There are options, like a Helix V8, Audiocontrol has a DSP/amp that has 2 RCA outs to go to a sub amp. Trinity makes a non-dsp staggered 8 channel amp that's pretty cool.
I like DSP amps a lot, but there are no cheap ones that offer a lot of power. If you want lots of power or may want to upgrade something you're better off using separate equipment.
Sennoupu (cheap Chinese company) does have a model (Hifi-12 I think or something like that) that has channels you can bridge to either run your sub or your midbasses, but I've never used it and only have read about 1 person that actually tried it.
The best DSP is a Helix. The miniDSP is also good. Minidsp does have the harmony DSP/amp as an option also, but the amp channels are not particularly powerful.
Some DSP amps will not let you bridge channels.
You'd have more options for power running a separate dsp and amp/amps versus a dsp combo amp imo
@Brax1942you know any place in AR that can tune a dsp? I haven't found anyone that said they could with any confidence 😂
6
105
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
540
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
301
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
712
Brax1942
CarAudio.com Newbie
Brax1942
Arkansas
chillin
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
