93 f150 single cab 2 10 ideas
  • 2
Here we go.....I used to own a 1500 ext cab Chevy but trans died and front diff cracked so its gone...now have a 93 f150 single cab got for 250 needed clutch runs great....but the lame sound *****....I have 2 massive audio kilo104 sub's and a 2k amp I'm just trying to get ideas here....option one try..to build box to fit behind bench but my sub's are not small so not sure how that's going to work...option two get 2 buckets and do some kind of console box but it can't get in shifters way....any input would be helpfull
I have a 94 Lightning and had 2 10" HDC3s between the bucket seats in 3 cubic foot net but no way you would have room to shift. I also had an 86 F150 with bench seat and was only able to get 2.2 cubes behind the seat without it having to be moved to far forward.
After looking up the subwoofer specs they only require 1.0 cube each ported. Id build a ported wedge box for behind the seat.
I'm just wondering if my woofers gonna rub the seat ,,,could get grills..screw it I'll give it a shot I got whole pallet of particle board given to me so its not like I'm losing anything but time
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
mjstutter12
toledo,oh
mjstutter12
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
