94 F150 stock radio Bluetooth mod
  • 1
ayriggins
CarAudio.com Newbie
MI
I have a 1994 Ford F150 with a stock radio that includes a tape player that I'm currently modifying with a Bluetooth receiver. My plan is to splice into the tape deck. I was able to get power to the Bluetooth receiver, but I'm struggling to get sound out of it. I removed all of the springs for the tape deck so that it always thinks there is a tape in the deck. The receiver has the red and white rca outputs, which I cut off to expose the wires. In each there is a white and red wire. I only used the white wire for both. I spliced them into wires that go into a harness for the tape deck that is labeled TAPIN, and also shows an L and a R for the red and white wires. My guess is that I'm not spliced into the correct wires for the sound. I'm including pictures that will hopefully give a clear picture.
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
ayriggins
CarAudio.com Newbie
ayriggins
MI
ayriggins
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
