A speakers impedance
  • 4
Brek
12
ky
I looked all over google for this answer and can't find it.
What determines a speakers ohms? is it the voice coil, the magnet, or both? does the thickness of the voice coil or how long the coil is or how big the magnet is have anything to do with it?
The voice coil. It's a combination of DC resistance (length and gage of the wire) plus inductive reactance (AC "resistance"). Typically about 80% of it is just the wire itself.
motor/magnet plays a large role in the BL of the sub, voice coil thickness affects its power handling and the type of wire used to wrap the coil determines it's impedance
DC Resistance is totally dependent on the gauge, length, and material of the coil.
Actual impedence at a given frequency and amplitude is a function of that, motor force (back EMF), inductance, mechanical compliance, the enclosure, the room/car, and thermal and mechanical compression at high power.
Thanks! It's what made sense to me. Just wanted to make sure.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
174
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
94
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Brek
Brek
ky
Kangaroux
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
