Adding Bluetooth to my vintage single Din deck
  • 2
OTW2KeelAManIBecame1
I have a Kenwood KRC 999 that I want to add BT capability to. I've seen some videos on this but they all require taking apart and some soldering. I was hoping for a less permanent solution.
Any suggestions would be appreciated. It has cd changer maybe that can be exploited?
784
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
696
Thanks. That makes sense. It sounds pretty good as is.
920
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn...
Bay Area
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
