adding speakers
  • Thread starter <paulo>
  • Start date
  • Replies 3
  • Views 2K
  • 2
<paulo>
Guest
i have a truck with only speakers in the front i want back speakers too, i already have them all i need is a plate or a box but how do i hook up the wires?
If your stock system consists of only 2 speakers then chances are that your head unit (if stock)is only 2 channels. You would need a 4 channel head unit or buy a 4 channel amp that can be hooked up to a factory head unit if you plan on keeping the stock unit.
I have two problems, my first is I cannot figure out how to post my question on the message board, my second problem is that I want a system that really bumps, you know a system where people can hear you coming, my only problem is i have a 1985 silverado, with a regular size cab it is about 5 feet long and about 8 to 9 inches wide. PLEASE HELP
Thanks. That makes sense. It sounds pretty good as is.
942
If you decide to sell those Polk MM Series Eggshapes before you blow them.. Let me know 👀 👀
825
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
737
Guest
mykeys
    May 18, 2024
    May 16, 2024
