My Headunit
  • Thread starter <Bassboy>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<Bassboy>
Guest
Yo, i have a Blaupunkt RPD 555 that puts out 55wx4, and has 1 set of preouts, look at this url and please tell me if it is a quality Deck.
Thanks
http://www.crutchfield.com/cgi-bin/S-WxZ3E9W3YSN/ProdView.asp?s=0&c=3&g=300&I=023RPD555&o=P&a=0
down here in the underworld, we see different model numbers cos of the radio bands that are used, but the sets are basically the same. i work in a car audio shop, and we have fitted 40 0r 50 of these....they go ok, only seen one or two come back faulty.
good value for money.
my opinion? save your pennies unless you never plan to build a big system.
what ^ said. amp gain setting info, test tones are at the very bottom...
301
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
930
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
931
Guest
duginnz
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
