aeroport flare questions?
  • 3
Pnshr13
CarAudio.com Newbie
I have done the calculations about a dozen times to make sure my box is as good as it can be. After taking away port displacement and woofer displacement, I should be right at 4 cubes give or take a .01 or .02...My question is I am using 2 4" Precision sound ports,a nd after calculations determined they need to be 13" each to tune to 33hz...My question is what is your thought on using the inside flare? I have heard some people use them and some that dont, but cant tell why they would or would not. any ideas or thoughts would be great. Just want opinions before I cut the center piece .
The only reason you wouldn't use the inner flare is because you're lazy or it won't fit. The air enters and exits the port on both sides, basics physics says that you'd lose efficiency by only using one flare.
So your concern is that the port seems too small for 2 subs? The port parameters are there.
Very Nice!! I have used regular sch.40 PVC in the Past for some box building while learning to do my own box tuning. Works great. Istill have a...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
323
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
Pnshr13
CarAudio.com Newbie
Pnshr13
central valley ca
THATpurpleKUSH
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
