amp cut out to 10% power and now the subs just hum even with the RCAs disconnected
  • 2
panfishpro
MI
hi I have a question about my system that I'm very puzzled about. I was bumping one day and all of a sudden my amp cut power to like 10% of its output and just makes the subs hum almost like some really bad distortion is happening. I removed the RCAs and am still having the problem. I also replaced the RCAs and the problem continues be it they are plugged in or not. any help is greatly appreciated. my system is 2 db drive wdx 2k 12 inch subs on a 2000 watt powerbass mono block. all my equipment is less than 3 months old. any feedback is greatly appreciated
Return the amp.
well I was wondering what I could be I am planning on returning it and upgrading but just for the sake of knowledge what could have caused this
the side closer to the amp of the fuse was melted. not sure what could have caused this but now I have all my power back because I replaced the fuse but now it only works with one RCA plugged in it doesn't matter which one but as soon as you plug both RCA cables in the amp totally cuts out
6
93
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
269
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
288
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
356
panfishpro
panfishpro
MI
panfishpro
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
